- I only think 5.
by warrior » Thu Jul 19, 2012 6:08 pm
I cant for the life of me get my steering wheel off my car, it is a bit crooked and it is driving me crazy! Does someone have a steering wheel puller I could borrow? Please!!!!!!!!!!!!! Happy to travel to pick it up and will drop it back when finished. Cheers
- I only think 5.
by warrior » Thu Jul 19, 2012 6:29 pm
tryed the normal stuff.......pull, twist, swear etc. Done plenty of wheels before but this one is stuck firm. Can buy wheel pullers from supacheap but dont want to just to straighten the wheel
Brainflex
by Brainflex » Thu Jul 19, 2012 6:42 pm
Has it had a wheel alignment recently? if so get them to sort it, if not its time you had one.
by evel » Thu Jul 19, 2012 7:11 pm
go hard
- I only think 5.
by warrior » Thu Jul 19, 2012 7:40 pm
can they sort it with a wheel alinment? i have one booked in two weeks
by sprsta » Thu Jul 19, 2012 8:04 pm
either the wheel aligners will do it for you or if you want to take it off yourself just loosen the nut but leave it on (otherwise you will punch yourself in the face) then pull back HARD wiggle side to side if you need to.
itll come off
- I only think 5.
by warrior » Thu Jul 19, 2012 8:09 pm
yeah have tryed that a few times..........need to soak it in CRC I spose then try again.
by Angreal » Thu Jul 19, 2012 10:38 pm
sprsta wrote:either the wheel aligners will do it for you or if you want to take it off yourself just loosen the nut but leave it on (otherwise you will punch yourself in the face) then pull back HARD wiggle side to side if you need to.
itll come off
I remember my one was stuck and it took much swearing, looking at the forums, swearing, looking again and eventually getting very forceful before loosening. Glad I didn't punch myself in the face though.
Was very hard not to chuckle amd hold a straight face when you were using I think it was a hammer and gave yourself a good wallop with the item last time you were working on my car...
maybe it was a spanner that slipped and got you clean in the mouth
by Angreal » Thu Jul 19, 2012 10:40 pm
And I guess that'll be the last time you touch my car now
by sprsta » Fri Jul 20, 2012 7:16 am
Yeah a hammer to the face does kind of suck
DBM58
by DBM58 » Fri Jul 20, 2012 7:49 am
I have some pullers that you can borrow. I am in Royal Oak, Auckland. Telephone 027 246 3767.
David
David
- I only think 5.
by Donovan » Fri Jul 20, 2012 8:21 am
Wait till the wheel alignment is done before you take the steering wheel off, as chance are it is the alignment that has thrown it out of wack. If you do it now, and then have the alignment done, chances are you are just going to have to pull it off and fix it up, as it will be squewed to the other side.
The worst alignment I have had was after my car was put back together, wheel was about 15deg or so to the left, after the wheel alignment it was pretty much back to the centre again.
by sprsta » Fri Jul 20, 2012 9:02 am
speaking of steering wheels ill come see you this weekend Donovan
- I only think 5.
by Donovan » Fri Jul 20, 2012 9:04 am
OMG, your still alive. Are you coming down to Taupo, as that's where I am this weekend, doing testing on the car after the last raft of changes. Drop me an email or txt sometime, maybe next weekend?
by sprsta » Fri Jul 20, 2012 9:20 am
ok ill txt you next week (sorry for slackness)
by Growler » Fri Jul 20, 2012 11:18 am
I have a set of wheel pullers too if you get stuck (West Auckland).
- I only think 5.
by warrior » Fri Jul 20, 2012 5:18 pm
Guys I did it! Got the wheel off today....lots of CRC , pulling and twisting!!!! Thanks for all the advice and offers of the wheel pullers. Just to let you guys know what you already do. This is a great forum and there are plenty of people willing to help out all the time, thanks.
