PLSEME
by PLSEME » Mon Mar 31, 2014 8:53 am
So im running Whiteline sway bars on my MX & over the weekend i realised ive destroyed my front sway bar mounts
Anyone running anything in the way of a Heavy duty sway bar mount ???
If so, who did you get them from ????
Or dose anyone just have some suggestions for replacments ????
by Junkwhale » Mon Mar 31, 2014 9:57 am
by SkilletKid » Mon Mar 31, 2014 6:25 pm
I've got the Racing Beat support blocks. If there's a large enough interest I can probably get measurements and get some made up locally. (Though I assume you will need new mount points regardless)
mjrstar
by mjrstar » Mon Mar 31, 2014 7:18 pm
I just welded in 50x50 3mm shs to support the swaybar. They are not going anywhere in a hurry.
by Ian » Mon Mar 31, 2014 9:44 pm
I'm also running the Racing Beat support blocks.
by SLYDIT » Mon Mar 31, 2014 10:39 pm
theres a wicked video i watched which was an under car shot at the mount while going around a racetrack....
definitly thought about the mount braces after that. the braces basically stop the mount from compreessing up towards the chassis and breaking.
PLSEME
by PLSEME » Tue Apr 08, 2014 12:54 pm
& the solution
