NA Minilites not fitting on hubs
kiwi73
Post by kiwi73 » Mon Mar 05, 2012 7:50 pm
Hi
My NA came with 15 inch rims. I tried to put the standard minilites back onto night. No joy. If this makes any sense...the center of hub is larger than the hole in the minilite as such the wheel will not fit flush on hub.
Is it possible someone has changed the rotors or are they same NA/NB
Many thanks
Paul
Post by Mr. Shine » Mon Mar 05, 2012 8:08 pm
Standard Minilites? MX-5s never came standard with Minilite wheels. I think that may be your problem, you've got non-standard wheels with too small a center bore.
Unless you mean the factory "daisy" wheels, in which case you've obviously got non-standard hubs, which sounds bizarre. Measure your hub diameter, it should be ~54.1mm I believe is standard.
kiwi73
Post by kiwi73 » Mon Mar 05, 2012 8:55 pm
Mr. Shine wrote:Standard Minilites? MX-5s never came standard with Minilite wheels. I think that may be your problem, you've got non-standard wheels with too small a center bore.
Yes they are the factory daisy wheels. Checked the hub 66mm. Go figure! Are the NB rotors any different than the NA?
Toolbox
Post by Toolbox » Mon Mar 05, 2012 9:27 pm
Hi..When you removed the wheels did you take of the wheel spacers or are they still stuck on the hubs. Hope this helps
2low2c
Post by 2low2c » Mon Mar 05, 2012 9:28 pm
sounds to me like the adaptor ring for your after market wheels is stuck on the hub .
kiwi73
Post by kiwi73 » Mon Mar 05, 2012 10:08 pm
2low2c wrote:sounds to me like the adaptor ring for your after market wheels is stuck on the hub .
Yes you'd be right. Wheel centering spacer was same colour as hub. Easily popped off.
Many thanks cheers
Post by brownie » Mon Mar 05, 2012 10:17 pm
photos would be a good help as well
