G4 PNP Issues - Update:New Help Required!
Question for yall:
I have a BP from a 97 NA SR Limited that I dropped in DEFCTV a few years back and im now going over to the G4 PNP.
Now at the time I went the lovely route of redoing all the wiring and fiddling with it until it worked. No easy task but I got there after studying wiring diagrams for what seemed like months. Which means I currently have the OBD 1.5/2 wiring for the ECU making PNP a no go.
I have reacquired a full set of looms to swap back to the early 1.6 setup however I’m wondering what else I may need to fiddle with to get it all working (NA for now)
It has no EGR equipment on it from stock, so basically my main concerns would be the Throttle body and coil setup as normally when people 1.8 swap they keep the 1.6 gear?
Anyone have any insight on this?
Last edited by Born_disturbed on Sun Feb 15, 2015 11:21 pm, edited 2 times in total.
Might be of interest
http://forum.miata.net/vb/archive/index ... 31355.html
http://flyinmiata.com/support/instructi ... .8swap.pdf
does this help?
http://www.miataturbo.net/megasquirt-18 ... 208/page6/
from memory the pins in the loom plug can be removed and moved around if required
Okay, progress has been made
Engine will start and idle when cold but only if the master fuel is above 40, idles best at 50 which is max, any less than that and it will idle for a few seconds then die.
Once warm it wont start at master fuel of 50, will at 40 but dies after a few seconds and same for lower numbers.
When it is idling hitting the gas kills it instantly.
IAT/AFM/TPS all disconnected and turned off, everything in the tables looks correct.
Full NA6/1.6 looms with associated bits (ignitor, relays etc) 1.6 coils, 1.8 injectors, 1.8 CAS.
Any thoughts?
Any thoughts?
Issue turned out to be not having an AFM connected, requires a signal from the open flap to trigger more voltage to the fuel pump. Jumped the 2 pins and it running.
Now to tap in a water temp sensor for the fans and fix the now failed water pump :/
Going to do the timing kit at the same time and, if I can sort some, I will upgrade the cams and get some adjustable cam gears too
But she drives! and drives well so I am happy.
