Polishing a hazy lens
Post by GRUVBB » Thu Aug 15, 2013 7:50 pm
Started new topic so others could follow advice if need be. Further to my fuel issues in general chat was asked why i do not polish my hazy boot lens?......... I have not seen this done before so do not have it in my knowledg bank. What is the best product to polish with? Something like jif or brasso? Big thanks to the replies that get posted. The generosity of forum members to help the less knowledgable is awesome. Its what makes a site like this work for the benefit of all.
Post by MrGrey » Thu Aug 15, 2013 7:55 pm
for starters, I don't think that light is required for a warrant, but the photo you linked makes me think that wet'n'dry sandpaper would help. Something like a 240 grit to start with then 600 grit then 1500 grit and then use a cutting compound and polish.
Post by Snapfrozen » Thu Aug 15, 2013 8:06 pm
This shit is amazing. As below. Sand them going from rough to VERY fine paper then use this. NZHondas has a good thread about headlight restoration. Remember to mask around so you dont get your paint
Post by sprsta » Thu Aug 15, 2013 8:08 pm
i scraped all the writing off my lenses when i had it stripped for paint,
dont go as course as 240!
start with some 800 wet
then 1500 wet
then 2000 wet
then 3000 wet
then use a buff to cut them back and make em nice and shiney
its time consuming but looks nice in the end
Hazy lens
Post by GRUVBB » Thu Aug 15, 2013 8:57 pm
Thanks Guys. I dont have a supply of wet n dry so will probably put funds towards a replacement lens. I have already ordered it so would not like to reneg on Ross. It's not a big outlay buying parts from MX5PARTS. Will allow me to use the time needed to go purchase wetndry and perform polish to do my trade and get paid for it. Will probnly work out cheaper in the long run. Thanks for the advice. Im sure many others will benefit from the thread read as well.i can polish mine at my leisure and put it in the spare parts dept. murphy law is when you got the part you never need it. Lol . Keep up the awesome posts everyone. :lol:
Post by MrGrey » Thu Aug 15, 2013 9:11 pm
just as an FYI, that lens is really easy to remove, just a couple of 10mm nuts hold it in place.
Post by authentic » Thu Aug 15, 2013 9:29 pm
MrGrey wrote:for starters, I don't think that light is required for a warrant.
Sorry man I'll have to correct you on that one. I got pinged for having mine too dim (had a small leftover LED bulb in there with the same base, but didn't give out 360 degree light) when taking it through VTNZ. Then again, it was VTNZ...
Post by brownie » Fri Aug 16, 2013 12:11 am
Anything registered for the first in NZ after 1992 must have a third Hi Stop light
Anything registered for the first time in NZ after 1992 must have a third Hi Stop light
Hazy lens
Post by GRUVBB » Fri Aug 16, 2013 6:13 pm
I had a rain off this afternoon so scored some wetndry on way home. 3 sheets $7. Ater about 30 seconds with 600 grit the lens was looking like this.
Then a stint with 800 and then 1200
Finally rreplaced lens and hit it with a polishing buffer. Took a bit of paint of around the lip but thats no drama.
Pics appear to have loaded in reverse order sorry. Also got a double insertion of first pic. My first time doing multiple pics.
Thanks for the polishing advice everyone. Hope this is of help and inspiration to others suffering hazy lenses. Im booked for a WOF tomorrow morning so hopefully allwill go well and ill be back on the roads. Just in time for the rain. Should be fun
Post by BRM » Fri Aug 16, 2013 9:19 pm
Always looks better smoothed off and shiney
Post by MrGrey » Fri Aug 16, 2013 9:26 pm
and most importantly, legal :)
excellent work :D
Haxy lens
Post by GRUVBB » Sat Aug 17, 2013 1:13 pm
Got the WOF. Stayed away from VTNZ. They wanted $51 for a check. :shock: why get ripped for an over the top fine tooth comb??? Good to be legal again.
Post by MrGrey » Sat Aug 17, 2013 2:50 pm
/highfive!
Users browsing this forum: No registered users and 61 guests
