Wheels
Registrar
Wheels
Post by Registrar » Mon Nov 14, 2005 2:50 pm
Just purchased a 1990 MX5 roadster (80,000k), unfortunately the wheels are
very tarnished.
Have tried water blasting, scrubbing with steel wool etc but to no avail. As
anyone got any bright ideas?
Keith Willson
Faculty Registrar
Faculty of Engineering
20 Symonds Street
Auckland
Telephone 64 9 373 7599
Facsimile 64 9 367 7156
Mobile 021 377 933
The University of Auckland
Private Bag 92019
Auckland
New Zealand
chrissy
Wheels
Post by chrissy » Mon Nov 14, 2005 3:07 pm
Why don't you just paint them silver?
chrissy
Wheels
chrissy
Wheels
Post by chrissy » Mon Nov 14, 2005 3:08 pm
I have some genuine Mx ones if you want to buy mine. Nice condition with
tyres. Chrissy
From supasparky@yahoo.co.uk Fri Apr 27 17:22:54 2007
b=e0FlNrBTdt223zVdbzs+rnw+mOHDTTkJdF3N6QsEHMMR/FJl2gtg9evb1O7YWDtk9nzEa7ZL6AuVfvEZciwKDLH2+gNneRAV9JNhkjvHyRpE0lqoEK5DnVeAM2e6w17KNRlxmBT46XRGugy3Gx7fRIqptRCPjTkZusLUL0peCIk=
Date: Mon, 14 Nov 2005 02:19:45 +0000 (GMT)
Subject: Re: Wheels
In-Reply-To: <001f01c5e8c0$3561bd90$9bd94aca@Chrissy>
MIME-Version: 1.0
Precedence: list
Message-ID: <940wtD.A.VHE.GxYMGB@L733>
one of the car cleaning product companies makes a
special mag wheel cleaner which has some sort of
etching quality to it which strips off the tarnised
oxidiesed layer of the aluminium. I cant for the life
of me remember if it was armoural, vht, crc, etc but
it definitly wasnt your run on the mill, spray on wash
off mag cleaners.
Glenn "SLYDIT"
chrissy
Wheels
tyres. Chrissy
Subject: Re: Wheels
MIME-Version: 1.0
Precedence: list
off mag cleaners.
Glenn "SLYDIT"
Badcat
Wheels
Post by Badcat » Mon Nov 14, 2005 3:23 pm
or try arrow wheels in west AK - they can repaint them with the right stuff.
ken
Date: 2005/11/14 Mon PM 03:19:45 GMT+13:00
Subject: Re: Wheels
off mag cleaners.
Glenn "SLYDIT"
uk.news.yahoo.com/hot/model-search/
ken newell
Badcat
Wheels
ken
Subject: Re: Wheels
off mag cleaners.
Glenn "SLYDIT"
ken newell
chrissy
Wheels
Post by chrissy » Mon Nov 14, 2005 3:39 pm
Some of those wheel products aren't good as I think they may have some nasty
things in them. Acid
chrissy
Wheels
Mark O'Sullivan
Wheels
Post by Mark O'Sullivan » Mon Nov 14, 2005 4:52 pm
Hi Keith
Send some pictures of your wheels to lance@arrowwheels.co.nz or shoot into see
Arrow Wheels at Patiki Road. Either way they'll give you a free assessment.
If the tarnish is as bad as you've described, it might take some reasonably
radical treatment to bring your wheels right again. Various treatments
include stripping the wheel of it's outer layer in a chemical bath, then
re-coating with paint and/or clear-coat as necessary. You might also want to
have any nicks or grazes around the rim machined to a smooth finish at the
same time.
Powerstrip Industries in Gabador Place East Tamaki are also another port of
call.
Mark
Mark O'Sullivan
Wheels
Hi Keith
same time.
call.
Mark
EricW
Wheels
Post by EricW » Mon Nov 14, 2005 7:27 pm
Most of these cleaners are based on Formic Acid, won't hurt the wheels, but
can do you a bit of damage if you don't wash it off your skin promptly.
Almost impossible to get off, if it dries on an alloy wheel, and it gives
off a nasty gas if you spray it on anything hot, like a brake rotor.
Eric
EricW
Wheels
Eric
Colin
Wheels
Post by Colin » Mon Nov 14, 2005 8:35 pm
I think that the Mothers and Maguire's are based on an oxalic acid. All of
the acidic type cleaners are just that. They will not leave a protective
film and will not without mechanical help (brush or scrub) even start to
lift oxidisation. They simply don't make them strong enough to do a lot more
than clean road debris and brake dust. Often they have trouble with tar also.
If you have cleaned the wheels with an acidic, spray on wheel cleaner then I
would suggest Mothers metal polish. That and quite a bit of elbow grease or
a small drill mounted foam pad will lift the top layer of oxidisation. It
is the first product Mothers made and is what they are most famous for.
Autosol will work also.
The use of wire wool or scouring pads is not something that will give a
polish. Aluminium scratches easily and using them will have removed any
protection. They will have oxidised almost immediately again. A natural;
although dull protection I suppose. Normal car polish on top of metal polish
can be effective for a short time.
I have a set of wheels (on a corolla) in a similar condition at the moment.
Some years ago I had the original 1994 wheels on the Mx5 repainted with a
two-pack silver to repair chip damage on the spokes. They look better than
they did new. They have been consigned to a box for the last few years
though so I am not sure how long they would have keep their appearance.
Phew...that was a bit long winded.
Oh, and for tar? Kerosene is the best solvent.
Colin
Colin
021 869 231
Colin
Wheels
Colin
Colin
021 869 231
Carey Hill
Wheels
Post by Carey Hill » Mon Nov 14, 2005 9:04 pm
Try Prestone wheel cleaner, spray on, leave for two minutes, scrub well
everywhere with a tooth brush, hose off
studefan
Carey Hill
Wheels
studefan
chrissy
Wheels
Post by chrissy » Mon Nov 14, 2005 9:06 pm
You could always take them to a metal polisher. They come up nice. There's a
guy called Wayne in Saleyard Rd Otahuhu. He polished up my Mercedes Wheels
and they were absoloutely awsome. The cost was $150. I had a quote on
getting a curbing mark removed from my Peter Brock wheel and I was told $150
for one wheel to repair. That was at Frank Allen tyres. I'd have to say the
guy in Otahuhu is great and I've used him to polish other things like cam
covers. If anyone wants his number I'll find it.
Chrissy p.s why don't you just my 4 spares for $290 and I'll throw in the
tyres. What a bargain.
chrissy
Wheels
WiM
Wheels
Post by WiM » Mon Nov 14, 2005 11:57 pm
First use wire brush, than polish with a quick turning device and
polish cream, after that clean with cleaning and degreasing product,
at this stage you can or paint the wheels in the colour you want
(after a first layer of base paint) or varnish the wheels. Important
to heat the alloys up to 50degrees Celsius, this way pores open up
and takes up paint much better, afterwards 'bake' the wheels at 55-
60degrees again.
Disclaimer: This is the theory, I have seen it being done but never
tried it myself. Maybe it's worth getting them refurbished by a profi
or get another set of wheels. I know I will try to refurbish alloys
at some stage the way I wrote above.
WiM
'91 1.6 MX-5 (due to immigration for sale)
www.mx5ireland.com
www.cardomain.com/memberpage/312875
Quoting Keith Willson <k.willson@auckland.ac.nz> on Mon, 14 Nov 2005
14:50:31 +1300:
very tarnished.
Keith Willson
Faculty Registrar
20 Symonds Street
Auckland
Mobile 021 377 933
Private Bag 92019
Auckland
New Zealand
WiM
'96 Subaru Legacy S/W GT twin turbo
'97 Suzuki TL1000S
www.mx5ireland.com
WiM
Wheels
60degrees again.
WiM
www.mx5ireland.com
14:50:31 +1300:
very tarnished.
Keith Willson
Faculty Registrar
20 Symonds Street
Auckland
Mobile 021 377 933
Private Bag 92019
Auckland
New Zealand
WiM
'97 Suzuki TL1000S
www.mx5ireland.com
Return to “2005”
Users browsing this forum: No registered users and 77 guests
