Turbo Manifold
Turbo Manifold
Now that i have removed the turbo from the GTI block i now need to source another manifold to mate the turbo to the NA 1600.
Whats the general feeling on what i should look for?
Cheers guys
Cheers guys
t2 is the flange thet the turbo bolts to the mani a t2 t25 t28 turbos etc will all have the same flange a t3 ect is not the same
most theap manifolds and turbos have a t3 flange i have noticed
i made my manifold. i just got some 90* schedual 30 bends from steel and tube and welded them together
works pretty well
works pretty well
I am sure yours is a Garrett T25--? Nissan use Garretts as OEM supplier.sprsta wrote:my turbo is nissan t25, think the crappy skyline ceramic turbos are t3
The "ChinaCharger" T3's available online almost anywhere are a pile of crap! Be prepared to trail smoke on 10psi after a month. If its cheap leave it alone.
I recently read an article from someone in U.S.A who had the front compressor housing split in half because the glue gave out- GLUE????
Users browsing this forum: No registered users and 115 guests
