Radiator Hose Supplier
If you ever need a hose for a non-standard cooling system, contact Hancock Industrial Ltd. Amazing service. I needed a hose to connect my coolant re-route pipe, which comes down the exhaust side of the engine, with a Civic race radiator.
I emailed them a photo, together with some relevant dimensions. They replied within the hour with details of some possible hoses from Mackay. I went into their place this morning and we tried out the ones they had selected with a scale model drawing I took with me. Found one that was a perfect fit, and only$11.
Definitely recommended.
I'm not sure if Kieth is using a spacer or not. I am using the Jackson Racing spacer, similar to the one you are offering in the classified along with a 1.6 (B6) cover. I made up a plug that screws into the tapped hole for the temp sensor.Papamoeziz wrote:Hey Keith, thats pretty good in terms of price! I'm just wondering what thermostat cover you went with on the back of youyr motor?
+1 for Hancock Industries
They have an extensive range and a model look up function with pictures and dimensions on their website.
Best of all they were 1/3 the price for a full set of radiator/heater hoses compared to John Andrews
El Tigre NA6T
Thanks Euen. Plan is to reuse the 1600 one. I've got a car that is a mishmash of engine/enginebay so just trying to sort out all the information on the Internet for 89 to 98 mx5's, with both 1600 and 1800 engines before I put it all back together.Euen wrote:I'm not sure if Kieth is using a spacer or not. I am using the Jackson Racing spacer, similar to the one you are offering in the classified along with a 1.6 (B6) cover. I made up a plug that screws into the tapped hole for the temp sensor.Papamoeziz wrote:Hey Keith, thats pretty good in terms of price! I'm just wondering what thermostat cover you went with on the back of youyr motor?
May the bridges we burn light our way
'89 mx5
'89 mx5
'78 808
'77 Mazda 1200 ute
'89 Toyota corona
'89 mx5
'89 mx5
'78 808
'77 Mazda 1200 ute
'89 Toyota corona
Users browsing this forum: No registered users and 102 guests
