Flywheels ????
Flywheels ????
Just interested to know what people are running???
Brands???
Weight???
What kind of trouble people have run into with lightened flywheels
Not sure if i should just buy something or lighten what i have.
Ive got a 93 NA8C, pretty much standard with an intake & exhaust.
Brands???
Weight???
Some Japanese thing that was pretty light. Car prone to stalling at idle in hot weather with the supercharger, a.c. running and on high octane. No problems on 91. Oh you also get quite a lot more transmission noise so I just turn the stereo louder
Other that the whining noise you won't have any problems on your stock setup other than stalling lots initially until you're used to it
TODA chrome molly ,From factory 9kg down to 3.5kg !!,Super responsive,Just get used to revs dropping quickly,No good if you are considering Turbo,You need the weight to keep the revs from dropping too quickly.
Best performance mod in my books without touching too much
- Attachments
- toda flywheeel.JPG (42.33 KiB) Viewed 22123 times
Hmmm didn't realise they made them lighter than what I have. I think my toda was 5.5kg but doesn't have all the holes. Probably good I didn't go lighter with the a.c. and supercharger drag. I would've thought a turbo would be happy with a crazy light flywheel but then again I'm not the most knowledgeable about cars
Have used a Racing Beat alloy flywheel 93 1., initially on the road and more recently racing only. Stalling has never been an issue...and shouldn't be on your set up.
Personally, I would not bother taking only 1 or 2 kg off a standard flywheel unless you were doing the clutch anyway.
There was a balancing company in New Lynn (Behind King Dicks). I had the flywheel lightened, then the flywheel and clutch assembly bolted together and balanced.PLSEME wrote:If i was to just lighten & balance my exsisting flywheel any suggestions on someone i should or shouldnt take it to
Im in Aucks.....
All up it cost me about $150 but that was about 15 - 16 years ago...
(I did the install though which saves money).
