Intercooler
Intercooler
I am upping the boost on my supercharged car so I am going to install an intercooler. What are people using out there? And can anyone suggest where to get a good intercooler from?
Looking at there appox sizes
width 400mm
height 200mm
depth 75mm
Any suggestions would be great.
width 400mm
height 200mm
depth 75mm
Ha ha....nice one. With a supercharger you need to go smaller than a turbo as you can run into massive idling problems with a core that is too large. This is the appox size that TRACKDOG racing sell in there kits for there superchargers.
Also would like a intercooler with top inlet and outlet holes if that makes any sence
Got my IC from LuxurySports in Neilson St Onehunga for $160.00.
Size is 450x180x65 & its a bar & plate one.
No complaints!
Just measure the space where you are going to put it as its a pain when they dont fit easily from word go! & keep in mind the inlet/outlet positions for the piping to route effectively.
No complaints!
Considering this was my second attempt it all boils down to forethought & also a lot of trial & error! .warrior wrote:Thanks wideopen, sounds like the go for me. silly question but how hard was it to mount and plumb?
Could take more pics but its all installed & covered now.
mine was also from ryan at LS
Cant beat it
it will come with some threaded nut things on top and bottom
i made brackets to hang it from the front bumper beam
and made all of the piping myself
http://www.mx5forum.co.nz/garage.php?mo ... age_id=357
Cant beat it
i had already removed my ac before the turbo went on
alot of people mount the intercooler behind the bumper beam so you cant see it from the front when the bumper is on
mine was mounted almost as far forward as possible
http://www.mx5forum.co.nz/garage.php?mo ... age_id=803
