turbo converted to a supercharger
Hi guys I was wanting to convert a turbo into a supercharger by changing the exhaust side to a pulley side and run it off were my air con belt was. Iv worked out how to gt up to a 16-1 ratio to the turbo so at 1000 engine rpm the turbo will b spinning at 16000 rpm. The turbo is a ihi wl85 vj330402 rhf5-18212w.
Q-1) Iv tride to find max turbo rpm so I don't kill it so if anyone could tell me Thatd b gr8.
Q-2) is the going to work
Q-3) if I attach a b.o.v and set it at a surten psi will that stop it from going any higher in psi
Q-4) also is the ratio OK like is it to high or to low and what psi should it give me on this setup .
Thanks guys hope some1 can help me
Firstly, it will be easier and cheaper to just buy a supercharger.
Max turbo RPM, well good quality turbos can rev up to like 10's of thousands of RPM's
Will it work, Theoretically I can't see why not, how well is another question.
B.O.V, Read up on how a BOV works because they don't open at a preset pressure, they use engine vacuum and a spring to open. What your thinking of is a wastegate.
Ratio, No idea.
Ratio, No idea.
Turbo bearings will not take the radial load required to tension the drive belt.
1- probably around 80- 100,000rpm max on that turbo.
2-probably not unless you can uprate the bearings or use a planetary gear to ups speed and take load off the turbine shaft.
3- technically yes you can limit boost by creating a leaky bov but this is not energy efficient. Common for early evos to leak at 18psi preventing further boost increase.
4- theoretical gut feel it may make a bit less than 10 psi depending on belt losses are you sure you have your ratio correct?
Begi manifolds - ekkk!
For $5800 we can do a full drive in drive out setup that will make well over twice the stock power, and be totally reliable
Or for $3000 a full supercharger setup - tuned and ready for action
If you're interested we have both turbo and supercharger demo MX5's that you can take for a drive to sample the end result
The supercharger kicks in as soon as you flick the switch on.
And you have boost from idle
The turbo will depend on what size - but I recommend the Td04HL which has full boost by 3000 rpm and usable boost by 2000
You can't run ITB's on a Supercharger setup, and on a turbo ITB's are a waste of time and very difficult to suit
You can PM us here or through our webside WWW.MEGASQUIRTNZ.CO.NZ or directly on e-mail MEGASQUIRT@FARMSIDE.CO.NZ
The turbo and intercooler won't really help much
most of the cost of installing an intercooler is the piping and labour
The turbo will have to be a Subaru TD type to suit one of our manifolds.
Although we could run an adaptor - but with a TD04L being around $150-200 it's not worth the effort
And we don't run BOV's on most of our kits
They're a waste of time on a properly designed setup.
Flick me an email for more details on
Forget a twin turbo setup - you'd have to use tiny little baby turbos in order to get any form of spool
4 cylinders don't lend themselves to twin turbos well
The supercharger setups get around 170hp at the wheels (200 engine hp)
and the turbo kits around 220-270hp at the wheels (260-300 engine hp)
We can do 400hp setups - but you really need a BP 1.8 engine and 6 speed for any form of reliability
The supercharger is hot side
Forget trying to twin charge the little 1600 MX5 engine
It will cost you a pile of money and the results won't reflect the cost
A TD04HL turbo on an 1800 engine will give you instant boost response and around 290-300hp on 20psi - at probably 1/2 the cost of twincharging
For a drive in drive out package you'll be looking at
$3200 for nonintercooled supercharger
$3900 for intercooled supercharger
$5900 for intercooled turbo setup
This is a comprehensive package including everything such as: ECU, turbo, downpipe, HD clutch, driveshaft hoop, dynotuning, intercooler, air filter, injectors etc and of course all labour
300kw at the wheels????? - You're obviously taking the piss.
You going to need a HIGH paying job if you want that.
The gearbox won't take it, the engine won't take it and the rear end won't take it.
I think you need to go for a ride in a well sorted turbo MX5 with 180-200kw at the wheels and stop thinking about stupid ideas like twin turboing, twin charging and 500hp 1600cc engines
a NA6 with 200kw at the wheels is a seriously fast car.
Users browsing this forum: Bing [Bot] and 4 guests
