Which ITBs
Which ITBs
Which ITBs
Silvertop 4a-ge
Kawasaki ZX10
Yamaha FX
Silvertop 4a-ge
Kawasaki ZX10
Yamaha FX
Depends how much you want to dick around, and how much you want to spend. When I priced getting a manifold fabricated for a set of AE111 (Toyota) ITBs, the estimate was around $900 - $1000. Jenvey are now doing an off the shelf kit for the BP4W head for GBP611. (About NZD1300).
http://www.jenvey.co.uk/home/standard-k ... it-ckmmz01
There are a couple of other items required like a vacuum manifold, throttle linkage and TPS but they don't add a lot more to the price.
The other thing to remember is that you will require an aftermarket computer to drive them properly.
here is a link to a very well priced set up
http://clubroadster.net/vb_forum/showth ... GE&page=19
this should help if you go the 4age route
http://clubroadster.net/vb_forum/showthread.php?t=39898
I would say find out what diameter will suit you best. There is calculators online for working out intake diameter/lengths for what power/rpm you are after.
Getting a manifold made up may not be to much of an issue if the throttle seperation is similar to the port spacing. It is possible to cut up a stock manifold and weld a flange on, or if using the bike carbs use the rubber sleeve things.
I remember someone was selling a set of cbr 600 (?) throttles with manifold for $250 a year or so back
garage star has adapters for 250us
http://garagestar.com/2010/10/29/miata- ... 0-29-2010/
ITBs?
Just wondering if this would be worth sticking onto my car or will it just cause me problems/make the car worse?
http://www.trademe.co.nz/motors/car-par ... 106500.htm
