MegaSquirtPNP
MegaSquirtPNP
The 'debut' MSPNP model# MM9093 offering is designed specifically for the 1990-1993 Mazda MX5 with manual tranny
http://www.megasquirtpnp.com/index.htm
around $700 it says ...
http://www.megasquirtpnp.com/mspnp_features.htm
... about double the price of a MSII assembled kit. And still good value!
FYI guys we've had people test the MSPNP MM9093 (for 90-93 Miata's/MX-5's) in Australia and the UK... it's been working well and I'd expect the same on NZ cars...
The MM9495 for 94-95 1.8l Miata's/MX5's was just released, it hasn't been tested overseas yet but time will tell. I don't expect any issues.
Jerry a.k.a. 'FoundSoul'
http://www.DIYAutoTune.com
have a look here for evrything megasquirt..
http://www.miataturbo.net/forums/forumdisplay.php?f=18
If you take away the spot-on base map (for a stock car) that we put hours, maybe days of tuning into, and the knock input, boost control circuit, launch control circuit, snazzy case, 4 bar map sensor with realtime baro correction (on the MM9495), the fact your AC will actually work (which won't be the case if you DIY one on a Miata), the months of testing to make sure everything is just right, and the first hand support capability we have with these cars because of all the effort we've put into this, then yeah, that's all it is .Psycho_Dad wrote:from what i can see. they are a ms1 with preloaded software and a mazda ecu plug?
or am i missing something amazing?
Psycho_Dad
