Light warning buzzer
Phil Dyer
Post by Phil Dyer » Tue Nov 20, 2001 9:55 pm
Was thinking of connecting a 12v buzzer in-between the sidelight hot wire and
the door switch so it sounds if I open the door while the lights are on. Has
anyone done this and found any problems?
Phil
Post by zorruno » Wed Nov 21, 2001 7:37 am
I have a slight step up from just a buzzer, and will be manufacturing quite
a few more in the new year.
They are 2/3 wire, and connect to door, lights, and IGN if you wish so that
they won't buzz if the ignition is on and you open a door.
They have a nice high pitched reminder, and are overall about the size of a
20c piece + wires.
zorruno.
Nigel Every
Post by Nigel Every » Wed Nov 21, 2001 9:50 am
Dick Smith has a Buzzer (about $14) that sounds if the ignition is turned off and
the lights are still on. bout a 10min job to fit.
Was thinking of connecting a 12v buzzer in-between the sidelight hot >wire and the
door switch so it sounds if I open the door while the >lights are on. Has anyone
Post by zorruno » Wed Nov 21, 2001 7:08 pm
out of interest, is the DS one 2, 3 or 4 wire? I saw the pic and it looked
like 4? IGN/GND/DOOR/LIGHTS?
Return to “2001”
