Rear disc's
rossandmeg
Rear disc's
Post by rossandmeg » Fri Nov 16, 2001 9:33 am
Can't remember if this has been discussed but can any one tell me if the 1800
rear rotors and callipers are interchangeable with the 1600 units ?
Ross Harvey
rossandmeg
Rear disc's
Post by rossandmeg » Fri Nov 16, 2001 11:29 am
Thanks Fletch,
.We are working on a race car and will be changing
front as well.
Regards...Ross
Fletcher Blades
Rear disc's
Post by Fletcher Blades » Sat Nov 17, 2001 10:01 am
They are not the same, if thats what you mean... you cant interchange one
piece and have it fit with the others... but I believe an "upgrade" from one
to the other is a simple as unbolting the old, bolting on the new, and
bleeding the brake lines...
I havent done it myself, but this is what I've been lead to understand...
If you dont do the fronts too, you will upset the brake balance... but
perhaps this is what you're trying to achieve? More rear brake power?
Return to “2001”
