Wheel Alignment
daca.robinson
Wheel Alignment
Post by daca.robinson » Sun Dec 22, 2002 8:38 pm
Hi.
I have discovered that the tyre's on the rear have the inside edges are badly
worn, not through to the steel webbing, but bad enough, is this a simple wheel
alignment or something more sinister.The rims are 15 inch with +35 offset?? on
Bridgestone RE710???
not to sure if the last two bits of info are necessary. I guess my question
is: a easy fix or not. ( where is the best place in CH-CH to Get it checked
out.).
can anyone advise.
cheers.
Daca Robinson.
jeff
Wheel Alignment
Post by jeff » Sun Dec 22, 2002 10:59 pm
Daca -
is your car lowered? A lowered car will have more
negative camber (sounds like you need less), wearing
the insides of the tyres out. Sounds like it's time
for an alignment! A search for "lanny alignment miata"
on google.com or the club site will get you some
starting specs...
If I were you, I'd flip the tyres to the other side,
get the alignment ... and corner a lot harder :D
Nice tyres BTW - wish they still made 'em !!
Jeff
--- "daca.robinson" <daca.robinson@xtra.co.nz> wrote:
Wheel Alignment
Post by biff » Mon Dec 23, 2002 12:55 am
The Bridgestone guyz on Morehouse ave in ChCh do a good job, and give a
club discount.
Biff
Return to “2002”
