Hi there,
does anybody know of a (right side) used electr.
window-opener motor ? If so, please e-mail to my
personal address . Much appreciated,
sincerely
Jill Sangl
electr. windowopener - motor
Are you sure its a motor you need?
There are several common problems... the switch gets dirty making poor
contact, the cables break, and occasionally, the plastic drum driven by the
motor that the cables wind onto shatters... all making the window not
open/close... but in each case, a new motor will not fix the problem...
So, unless you've already investigated further, just assuming you need a
motor because the window isn't winding is usually a wrong guess.
In anycase, the parts you need are available from Ross at www.mx5mart.co.nz
