- I only think 5.
by warrior » Tue Oct 21, 2014 6:05 pm
I want seem weld on my door openings to stiffen the car up. I have done a bit of research on this and looks quite straight forward.
There is only one problem...I cant weld.
Is there anyone out there wanting to do this for a job (money or beer will be paid)
I have been told to weld a short bead (about 1 inch long) then skip ahead 2 inches then weld again.
All the welding will be covered by the door opening trim.
I can clean off the points to be welded and get them ready then all you have to do is weld them, should not take to long.
Anyone out there?
by SLYDIT » Tue Oct 21, 2014 8:35 pm
do you have frog arms fitted?
- I only think 5.
by warrior » Tue Oct 21, 2014 8:58 pm
No but I have bought some and they should be here by Monday
by REDBEN » Tue Oct 21, 2014 10:31 pm
Warrior flick me a PM I can probably do it as I have recently done mine.
- I only think 5.
by warrior » Wed Oct 22, 2014 7:25 am
How did it make the car feel? Was it worth doing?
by sprsta » Wed Oct 22, 2014 8:09 am
I would just double or triple spot-weld the door openings
faster, tidier, and just as stiff.
I can do it if you like.
- I only think 5.
by warrior » Wed Oct 22, 2014 8:12 am
What area are you in mate?
by REDBEN » Wed Oct 22, 2014 11:06 am
I won't know until the car is back on the ground off the dolly, but I would imagine a lot with out the added weight of braces....
by sprsta » Wed Oct 22, 2014 5:15 pm
Auckland central.
- I only think 5.
by warrior » Wed Oct 22, 2014 6:07 pm
Thanks mate, I got your message just been a bit busy. I will give you a call tomorrow to have a chat.
Thanks guys.
