by Furai » Sat Feb 02, 2013 10:10 am
This one.
malcster
by malcster » Sat Feb 02, 2013 10:45 am
cheers...best place to get?
1998 NB MX5 RS TURBO.
Badcat
by Badcat » Sat Feb 02, 2013 10:51 am
i need one for my NA if anyone is doing a group buy...
malcster
by malcster » Sat Feb 02, 2013 1:45 pm
i have asked a contact in the states(lsd motorsports) if they can get beatrush so will keep you posted.
by Angreal » Sat Feb 02, 2013 2:39 pm
malcster wrote:i have asked a contact in the states(lsd motorsports) if they can get beatrush so will keep you posted.
You may as well get it direct from Japan as it saves on double handling the product as they'd have to ship it to the states and then ship it here. I was originally going to get it from Goodwin but he needed to order it from Japan which meant delays. Got it direct from Beatrush and it took about a week and a half.
malcster
by malcster » Sat Feb 02, 2013 2:51 pm
o.k..looked at the japanese site before but how did you order from it?
by Angreal » Sat Feb 02, 2013 3:04 pm
malcster wrote:o.k..looked at the japanese site before but how did you order from it?
I just emailed Ewan and asked him to buy me this brace:
http://www.laile.co.jp/jpn/products/par ... 81PPF.html
Just make sure that the mounting points are on your car. Furai will know more about it, I just know my car had them
malcster
by malcster » Sat Feb 02, 2013 3:15 pm
cheers..have sent him an email.
by Angreal » Sat Feb 02, 2013 3:38 pm
Actually you have an NB so it'll have it. Make sure you buy the NB brace. I think that was the NA brace
malcster
by malcster » Sat Feb 02, 2013 3:56 pm
ok.cool..yeah i emailed him pic of the nb one
by Furai » Sat Feb 02, 2013 4:20 pm
Yeah all NBs have the points for it to my understanding. Make sure to link the one for NB8C as they are all different.
malcster
by malcster » Sat Feb 02, 2013 4:59 pm
yeah linked the nb8c one.
works out just over 200nzd to my door from Ewan ..goodwin wanted 215usd shipped so will be going ahead with that.
by Snapfrozen » Sat Feb 02, 2013 8:30 pm
I'm going to make a jig for an NA6 one if anyone's interested. Will get pics up once I make the first one.
Can't justify buying one when materials are so cheap!
by siren676 » Sat Feb 02, 2013 8:39 pm
Snapfrozen wrote:I'm going to make a jig for an NA6 one if anyone's interested. Will get pics up once I make the first one.
Sounds good
2low2c
by 2low2c » Sat Feb 02, 2013 9:54 pm
no brace is going to cure this problem the PPF brace will stiffen the diff movment and actually make it more noticeable [did on my car ] if you have a fault with the car i would look at the rear bushes if that is all okay them try lifting the rear of the car by 5 to 10mm .
malcster
by malcster » Sat Feb 02, 2013 10:34 pm
i dont think i have a problem with the car..its just the 200+hp going thru the back wheels that causing the loose feeling issue I think but the brace I know can make the diff a bit noisier as it ties everything together more but thats fine as get plenty of induction noise now...and the brace should tighten things up...well thats what the research is telling me..it cant hurt to try it anyway
by Timmo » Sun Feb 03, 2013 10:11 pm
What about your diff bushes? If that's rocking around on its mounts then that could adding some odd sensations to the rear
by MrGrey » Sun Feb 03, 2013 10:28 pm
I too would be interested
MrGrey on Mon Feb 04, 2013 11:07 pm, edited 1 time in total.
by Euen » Mon Feb 04, 2013 4:49 pm
malcster wrote:
funny you mention the suspension as RH REAR to get ride height needs to be totally uncaptive spring but LH side spring is wound up and captive some.
and opposite to the front as LH uncaptive and RH is captive...had to lower it heaps with the 15s on it and with 17s i had before the springs were never un captive but were wound out differently like now.
Are you sure that you have the front and rear springs on the correct corners. With different length springs you would get the adjustment conditions you describe above and that may be causing your instability.
malcster
by malcster » Mon Feb 04, 2013 6:25 pm
it appears so(have measured the springs)...may take the springs off and get them tested..sometime
the shimmy isnt to bad..just when the boost hits hard and its fine under usual more gentle acceleration.
tsoob
by tsoob » Mon Feb 04, 2013 10:42 pm
Has anyone found a decent Adjustable camber arm for these vehicles? With the new camber laws its a headache getting any decently lowered MX5's certed.
by siren676 » Mon Feb 04, 2013 11:07 pm
In short, no. The ones that are sometimes on trademe are crap, have heard they dont fit properly and get flogged out easily.
Cant say ive seen any other brands
Edit, looked back through a few threads and it seems that offset bushings in the upper control arm would be a good bet.
by Kieran » Tue Feb 05, 2013 1:32 pm
tsoob wrote:Has anyone found a decent Adjustable camber arm for these vehicles? With the new camber laws its a headache getting any decently lowered MX5's certed.
There are really only two options extend the RUCA's to add positive camber unlikely to pass cert... if they spot it
Otherwise spend over 1K on some DGM RUCA's when they are released
http://clubroadster.net/vb_forum/22-sus ... rucas.html
by Furai » Tue Feb 05, 2013 1:40 pm
Cant you get different lower arm bushes that allow more camber correction?
by Euen » Tue Feb 05, 2013 3:03 pm
A bit on the pricey side but Flyin Miata stock the V8 Roadsters bottom front arms which have an extra adjuster on the outer knuckle.
http://flyinmiata.com/index.php?deptid= ... %20%20LEFT
On the rear they put the extra adjuster on the top arm.
