I have fitted a similar unit from Loch Stewart (http://www.miata.net.au/loch.htm)
My opinion is that if I drove a car that had one, and mine did not, then I would want one, as soon as I could. A relatively in-expensive way for a bit more fun at higher revs.
I am in Auckland, you are more than welcome to come and have a go if you like.
David Moughtin
From Michael_VanZoggel@bcait.com.au Fri Apr 27 16:51:53 2007
Subject: RE: MX5Mania intake
Date: Thu, 5 Feb 2004 15:12:23 +1100
Thread-Topic: MX5Mania intake
Thread-Index: AcPrk5COD71MKluxSMipG8IlBVxT4QAAwdMQAAG0mpA=
From: "Michael Van Zoggel" <Michael_VanZoggel@bcait.com.au>
Message-ID: <wr-tk.A.inF.MIYMGB@L733>
I also have the Loch kit, which is pretty similar, except that it is 3" through the firewall, and has the same diameter through the unit - ie.. it gradually narrows from the filter to the 3" end point, rather than a section sloping up at a steeper gradient.
Whetever - too hard to explain. It's a bit bigger as the end result.
The gain however, feels like 15% more at the seat of the pants. It's not (I've read figures of ~5%, which is probably true) - the extra 10% can be attributed to the fantastic noise under load (does not drone like a big exhaust - only loud when you acclerate - the harder you put your foot down, the loader it goes) and the fact that it opens up the top end.
Best $275 I ever spent. Do it and the 14Deg BTDC at the same time and you have a new car.
Cheers - Mike
MX5Mania intake
MX5Mania intake
David
MX5Mania intake
I've had a Loch Stewart intake in the past (his older style one though)
and totally agree that they are money well spent. I recommend them and
any other kits of similar design (like the Mx5mania one).
M@
Message scanned by the Sheriff
M@
