New Subject Headlights
brentweaver
Post by brentweaver » Fri May 05, 2006 1:06 pm
BlankHi All,
My '93 5 is causing some frustration at the moment. The pop up
headlamps will not retract. I have just fitted a buzzer to warn that my lights
are still on, but that is not directly wired to the h/lamp system but the park
light system & windscreen wiper system as per instructions for fitting the
buzzer. I can wind them down manually but they just go up again. It makes no
difference if the headlights are on or off. Could it be an earth problem? or
some other electrickery problem. Any ideas much appreciated.
Thanks, Brent Weaver.
From jifjif@gmail.com Fri Apr 27 17:58:31 2007
b=BBMn/UgecEOySBZ+wbb6c63DIStBVFGwLMSswOQGM+lssLm3xekfR7ZZkOSZ0KfHbu39QYIWKp+W8OO2odKMH6ImmSPTUS3pet4YUqi9qu13CALVlgrDNfju9SdPvAH8OLPzMroPGFrlXQDZKfpb9LRL7TE8cDb953PuE2To1zA=
Date: Fri, 5 May 2006 13:58:49 +1200
Subject: Re: Speaking of manual boxes
In-Reply-To: <445A9EDB.10004@clear.net.nz>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
References: <445A9EDB.10004@clear.net.nz>
Message-ID: <HNqn5D.A.9SH.bGZMGB@L733>
changing the gearbox (and turret) oil, to something synthetic
preferably, is the usual recommendation. :)
http://miata.net/garage/trans/08.htm
FWIW, my '96 was also notchy even when it was only a few years old. I
think the synchros suck slightly... :P
On 05/05/06, Colin Larsen <cglarsen@clear.net.nz> wrote:
ianbell
Post by ianbell » Fri May 05, 2006 8:15 pm
BlankHi Brent
I fitted a lights buzzer last week and have no problems. I put the buzzer
between the ENGINE to the PARK LIGHTS fuses. Ian Bell
CHN433
Return to “2006”
Users browsing this forum: No registered users and 79 guests
