I would like to know where the horn fuse is please? can you tell me exactly
which one and also where to find the horn relay for a 1990 MX5. Thanks
Chrissy
Email lists
Email lists
Hi Chrissy
The horn fuse will be in the fuse box under the dash. Not sure which one it
is on a 90 but may be the same one as the stop lights.
The relay will be under the bonnet on the left hand side. It may be covered
by a rubber boot. On the 96 it is on a small metal bracket with the park
light relay and the headlight relay. The horn and park light relays may be
labelled "LA10" and are smaller than the headlight one.
Email lists
What about this link:
http://www.mx5club.org.nz/maintenance/fuses/
By the way, if your car has air horns fitted, there may be an extra in-line
fuse (follow the wires from the compressor to find it. The compressor will
be connected to the horns by a length of plastic tubing).
As Euen ponted out, I think the horn shares the same fuse as the stop
lights.
David Moughtin
lights.
David Moughtin
Email lists
I know where the fuse box is. I need to know which fuse? and can you tell me
exactly where the relay is. Thanks
From eric@hayleymedia.com Fri Apr 27 17:56:31 2007
Subject: RE: Car immobiliser for insurance and the name of a good
mechanic
MIME-Version: 1.0
Date: Mon, 24 Apr 2006 09:17:33 +1200
Thread-Topic: Car immobiliser for insurance and the name of a good
mechanic
Thread-Index: AcZmvophlCNCSWA/RK+j0C8UilavggAXD4GA
Precedence: list
Message-ID: <tXmXiB.A.uPH.bGZMGB@L733>
I am insured with AA, they require an alarm with infrared detectors and
an immobiliser. I have a Mongoose which was installed by Automotive
Security Systems in Glenfield. Insuring the car the first time is an
expensive business, but having had a major claim recently and having it
so hassle free, is worth the cost of insuring with a good reputable
company.
Eric
________________________________
From: e-admin@mx5club.org.nz [mailto:e-admin@mx5club.org.nz] On Behalf
Of Jolyon Russell
Sent: Sunday, 23 April 2006 10:13 p.m.
To: mx5list@mx5club.org.nz
Subject: Car immobiliser for insurance and the name of a good mechanic
Hi,
I just purchased a 1989 model and have been told by my insurers that I
need a dual immobiliser.
1. Can you recommend any insurers?
2. Can you recommend any brand of immobiliser that is well suited
to our cars?
I would also like to have this car thoroughly checked by a mechanic who
specialises in MX5's. Who do list members recommend in Auckland?
Regards,
Jolyon Rusell
From supasparky@yahoo.co.uk Fri Apr 27 17:56:32 2007
b=0GSISz1N7LmNIgrIBOcvlF0aX5s0FGP6A0J/L5jJeSOePGU3yLdtu0On2pjCLx1tE2Nby+dCIsuaO14lnUw2GoQ7s+3aovzBxL7VTN+LcJ1GN28byJG6fUzhV6U1I8gu93BRtfVnojs78iWwDegn+D/bz1RcIli25eSlPXc8IT8=
Date: Mon, 24 Apr 2006 03:36:47 +0100 (BST)
mechanic
In-Reply-To: <002301c666bf$b92eda40$0a02a8c0@Justin>
MIME-Version: 1.0
Precedence: list
Message-ID: <o5QbWC.A.vPH.bGZMGB@L733>
You could ask your insurer what brands they endorse
and installers.
BUT BE WARNED!!
Most installers get paid stuff all to get the alarms
in and they often do a very poor job. Make sure you
tell them you want a good job done and you want to see
the end result Before you pay...
My "insurance approved" alarm system was thrown in and
wired right under the steering column with the siren
fuses right next to the ignition lock.
Now if you are a theif about to steal a car where is
the first place you look??? Thats right. Next to
the ignition!It would have taken 1 second to disable.
I ripped it out and reinstalled it using hidden
wiring, and new location.
Moral of the story, the alarm is only as good as the
Installer!!!
Glenn "SLYDIT"
Hairdressers car??? well no. but it does have a HAIR DRYER!
mechanic
MIME-Version: 1.0
mechanic
Precedence: list
company.
Eric
Of Jolyon Russell
Hi,
to our cars?
Regards,
Jolyon Rusell
mechanic
MIME-Version: 1.0
Precedence: list
and installers.
BUT BE WARNED!!
Installer!!!
Glenn "SLYDIT"
