by Angreal » Sun Dec 25, 2011 12:03 am
So while swapping the original dashboard in my NA with an NB one I came across a small problem.
What's the easiest way to remove the HVAC? Also, does anyone know the best way to reattach the 3 cables? I have worked out the wiring but I haven't worked out how to reattach the cables or whether I'd need the NB cables and connect them at the other end. Any advice from someone who's done the NA NB interior swap or has some experience with the HVACs would be much appreciated.
by sprsta » Sun Dec 25, 2011 6:26 am
just use the cables on the nb controlls they will work correctly
by Angreal » Sun Dec 25, 2011 10:38 am
Cheers for that and Merry Christmas. I'm slowly getting there...
by sprsta » Sun Dec 25, 2011 2:30 pm
if you dont have the cables attached to the controls you can have mine
by Angreal » Sun Dec 25, 2011 8:50 pm
Yeah my cables on the NB unit were cut. For now I'm just focussing on getting everything swapped over before getting everything running again.
Users browsing this forum: No registered users and 72 guests
