euno roadster 1600 1993 refuses to idle unless ac on
allenbak
Post by allenbak » Thu Jan 09, 2014 3:34 pm
no idle for motor unless a/c is switched on, motor dies when put in to neutral manual gearbox. any place to look for problem?
Post by jif » Thu Jan 09, 2014 5:05 pm
the idle air control valve would be my starting point :)
On 9 January 2014 15:34, allenbak <electrical@mx5forum.co.nz (electrical@mx5forum.co.nz)> wrote:
Post by 4A-GE » Thu Jan 09, 2014 5:07 pm
Mine [before I bought it] had issues with a relay of sorts up by the brake booster, try that and/or any other relay.
Post by WideOpenThrottle » Thu Jan 09, 2014 5:23 pm
Clogged air filter-faulty AFM-vacuum leak-fuel mixture?
allenbak
Post by allenbak » Sat Jan 11, 2014 1:34 am
put new plugs and leads, #2 plug was not in properly oil coming out passed plug, causing misfire and lack of idle, adjusted idle screw lightly after work done, solved problem, put polymer into oil to help seal any leaks from inside the motor. went for a good run, performed great, the plugs where all loose, I think previous owner forgot to torque them to correct spec. Now I know they are done. Gives me a lot more confidence to drive her anywhere. water system completely renovated professionally GT Autos Auckland, did a brilliant job. idle air control valve given throttle body cleaner solution works well. thanks for all your help
Post by MrGrey » Sat Jan 11, 2014 2:40 am
excellent news!
I hope things run nice and smoothly for you from now on :)
Users browsing this forum: No registered users and 60 guests
