Sequentail shift light
Post by warrior » Tue Mar 26, 2013 10:23 am
I have bought a sequentail shift light (why? beacause they are cool) and have a question about wiring it in. It can be plugged straight in the cigarete lighter but to be 100% accurate it needs to be hard wired in.
It only has three wires
1. GREEN: NEGATIVE
2. RED : POSITIVE
3. BLUE :COIL/ ECU SPARK WIRE
So the BLUE wire goes to either a coil or the ECU on a "wasted spark distributor-less"
Which one is a NA mx5? I am guessing the wasted spark system?
If if is does anyone know the colour wire I should connect it to on the ECU?
I hope this makes sence.
Post by sprsta » Tue Mar 26, 2013 1:23 pm
use the tach signal wire that goes to the dash
Post by warrior » Tue Mar 26, 2013 5:17 pm
Have just pluged in into the cig lighter socket at the moment, set it up and it works great.
Users browsing this forum: Bing [Bot] and 11 guests
