Removing proportioning valve on Master cylinder?
So I need to improve rear brakes. My car is firm and low and for my Certificate test in NZ it locked the fronts too easily and barely worked on the back.
I have checked everything is working properly and it is, I had the brakes properly tested and its all normal for an MX5 but Im running 12/10Kg springs so I dont have much if any dive.
So has any tried removing the proportioning valve? I could get an adjustable one but it takes too long and I will run out of time to get my cert(Has to happen withing 2 months and I have about a week).
The other option is upgrading the rear brake calipers or bigger discs but it seems to be clamp pressure when using the pedal is the problem(Use the handbrake with the footbrake and it slows better and you can feel the back working)
chances are because you use the hand brake for drifting that you have glazed the rear discs so they may just need a skim to clean them up and improve the bite .if you remove the factory proportioning you would have to replace it with an ajustable one(wilwood)
A proportioning valve seems like it would be trying to work around an underlying issue -- whether mechanical or questionable testing methods.
I'd look at new pads, skim the discs. Are you running the same type of pads front and back?
You will still be getting load transfer even if you made the suspension completely rigid, so long as the centre of mass isn't on the ground.
If you are heading down the direction I think you are then give Cardwells a call. They do a Willwood one and if I remember someone has found a part you can use to remote it...Furai wrote:Who sells wilwood in NZ?
http://www.flyinmiata.com/support/instr ... _valve.pdf
And it is a known problem with MX5's in racing that they lock the fronts easily. The bias is great for a road car..
Here Furai - What I was looking for...
I believe "Thepass" also has one in his car but cant find the thread.
http://www.miataturbo.net/race-prep-75/ ... all-37313/
thats my point...many of the bias valves only reduce the rears not make them better. most race cars are over braked in the rear and you tune them down with the bias valve but not increase them compared to the front..Mad Kiwi wrote:Was there any solution to this problem?
I have read the valve only reduces the bias to the rear so it makes the problem worse....
Yes and yes, Bought new calipers for the rears ages ago and overhauled before putting in.marcellarius wrote:I'd be looking at the rear calipers -- have you done a full R&R on them? If they are jamming up then that could cause a brake balance issue.
Do you have numbers that show the problem, like from a brake tester used at some WOF places?
WOF Machine said its pulling 1000NM which is fine.
But if you slam the brakes it locks the front more passenger side so we are thinking sticking caliper. Thats the cert issue.
The lower CoG is going to give you more of a front bias under deceleration, I'm not sure how significant this effect would be; it's not that low.
Could it be weight distribution related? Does it still lock up with a passenger in the car? 12/10 springs are pretty hard, could that be putting your corner weights out enough to cause that?
that is actually incorrect the fatory valve is set at 50 percent of the front pressure a willwood valve can be ajusted between 43 and 100 percent of the front pressure so you can infact increase the rear brakeing over factory.
Eliminated weight, tried with/without passeger, different rake, dampening, compsating for weight, Its the brake system.
I just replaced front pads and after a drive the side that isnt locking is leaking fluid so another thing to fix that could be the issue.
Moral of the story is ever since going for cert EVERYTHING has gone wrong. Dont go for cert
