Replacement brake caliper
Post by marcellarius » Sat Sep 07, 2013 4:31 pm
So, I was torquing up the guide pin on my front left caliper and all of a sudden it got far too easy to turn. It didn't feel crossthreaded when I started it by hand and ran it down with a ratchet but the thread on the caliper has been taken right off.
The caliper needed a rebuild anyway, the other side isn't great either. Is there anywhere locally that sells rebuilt front calipers for an NA8C?
Otherwise, I was thinking of trying to find a decent second hand one and rebuilding both.
Post by MrGrey » Sat Sep 07, 2013 7:11 pm
Try contacting Ross at mx5mart, he should be able to supply the bits you need :)
Post by Snapfrozen » Sat Sep 07, 2013 9:43 pm
Keep in mind the calipers are the exact same as the NA6C... The pad bracket and rotor are what make them different
