Finally decent adjustable camber arms?
Post by Furai » Wed Jul 31, 2013 4:15 pm
http://www.mx5mania.com.au/product1743.htm
Post by Furai » Wed Jul 31, 2013 4:18 pm
Seems to be a popular theory.
http://store.awrracing.com/suspension-7/
Post by chris » Wed Jul 31, 2013 4:22 pm
Hmmm, wonder what certifiers would say about them..
Post by siren676 » Wed Jul 31, 2013 5:12 pm
Furai problem with those arms is their main intention is to add more camber not zero it out, I dont think there'd be enough meat left in the arm if you sloted the hole out towards the end of the arm.
Also not too sure weather lvvta would allow them
Best option is to use offset bushes like the ones used in Hayley's car
Post by SkilletKid » Wed Jul 31, 2013 9:33 pm
Post by Furai » Fri Aug 02, 2013 7:11 am
siren676 wrote:Furai problem with those arms is their main intention is to add more camber not zero it out, I dont think there'd be enough meat left in the arm if you sloted the hole out towards the end of the arm.
They are slotted out as well as inwards for positive or negative adjustment and the description says " to get rid of unwanted camber when lowering vehicle "
hlau028
Post by hlau028 » Fri Aug 02, 2013 9:50 am
Where might one find and purchase these offset bushes?
And how much do they cost?
Thanks :D
Post by siren676 » Fri Aug 02, 2013 10:30 am
Uhh it doesn't say that it says "cheap and easy way to get more camber"
Just look at how little material is left on the arm after slotting it, there's no way you'd pass cert like that.
Have you seen how far people have had to extend their factory arms to reduce the amount of camber.
Post by chris » Fri Aug 02, 2013 10:40 am
I was thinking certifiers would have issues with this too..
It's a good idea. In theory.
Post by Furai » Mon Aug 05, 2013 1:37 pm
Read the AWR Racing one not the MX5 mania one. One says more camber and one says more or less.
I think I will buy the offset bushing Hayley got but I guess if you wanted these just ask one of the certifiers about them.
