had a wheel alignment about a month ago with 2 new tyres as usual.
noticing as last time it goes out of alignment within a month or so mostly the front toe adjustment and the back camber seems to increase.
is their any whey to remedy this?
new alignment bolts?
tighten the shit out of the bolts?
wheel alignment problem
New Eccentric alignment bolts
http://miataroadster.rpmware.com/mazda/ ... 12510.aspx
Is this what someone might call a 'camber pin' '? Last alignment I was told I'd need to replace mine.Kieran wrote:New Eccentric alignment bolts
